Radiator Recommendations?
    Originally posted by trwp72 View Post
    Thats what I hate about the plastic / aluminum radiators... the tanks always leak... they either crack, or the seal between the tank and the core starts leaking. The tanks are crimped to the cores with a gasket to seal it.
    Copper FTW!
    -Phil
      actually the aluminum is a fair bit more efficient than the brass radiators. A 2 core brass sheds heat about the same as the weenie single core aluminum does. The crappy crimped side tanks are teh crap though. 86VickyLX has some rather hefty all-aluminum thing that I like the looks of. Looks like some sort of fancy high performance custom job with welded seams and all. I think my next radiator will be one of those. 2 or 3 aluminum cores should evict all the heat I would ever generate.
        I made my response at the bottom of this thread --
        http://www.grandmarq.net/vb/showthre...ht=#post575665
