The later ECMs also have a considerably different pinout, so they are a lot more trouble to swap in. You can dig up the connector diagrams if you'd like but using the 93- mass air ECM requires moving 2 or 3 wires. Using a 94-95 requires moving about half of the connector around. It can be done, but its far more trouble to keep track of. That, and the other inputs you don't currently have wiring for and may or may not be able to implement.
Stock injectors capabilities?
Originally posted by turbo2256b View PostThe ECM yes but not necessarly the cam. The ECM can be repinned with the lopo firing order. There will be arguments on this but I ask a Ford engineer in the programing and tuning for Ford if it would work with no issues and he said yes. Did it and drove the car for 4 years or more.
Originally posted by sly View Postwhile true, the fact that two cylinders in the firing order are on the wrong bank according to what the ECM expects will make O2 trims get stupid unless you put no cats until post H-pipe and put the O2s in the H-pipe (keeping them as close to each other as possible) making the fuel trim work on both banks. Essentially tricking it into working like a batchfire O2 using SEFI. Without this kind of modification, you risk having one bank lean out while the other is rich as hell.Last edited by 90ltd; 09-02-2013, 11:48 PM.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Originally posted by 90ltd View PostSo if i replace stock 14s with 19s will stock ecm compensate? With stock injectors I started running lean at 4k rpm when dyno operator stopped the pull. I probably could have gotten 160 rwhp which is stock auto fox mustang output.
Why not just do a full proper HO/Explorer swap and not worry?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
On the on the ho swap: right now I'm pretty close to gt output and explorer engine has the same torque so no go. One thing i noticed is that almost all parts add horsepower but not torque. __“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Originally posted by 90ltd View PostCan i switch o2 sensors to fix it(right sensor in left bank and vice versa)? Or splice both sensors into one?
If the stock ECM cannot be tuned for more injector, and I really have no clue of it's capabilities, its possible you might be able to tune one of the HO brains to run with a different firing order. If you can change the injector size and all the other stuff, why not the firing order?86 Lincoln Town Car (Galactica).
The O2 sensors dont make a difference if you know injector order has been changed. Smaller or larger injectors can not be swapped with an ECM as its not the flow that is the issue with them not working. Atuner like the Tweecer there is a a app to change injectors, firing order, distance of O2 Sensors in case of long tube headers, change opening or closing of injectors, acclerator pump discharge squiter size, duration of squirt, A/F ratio WOT, load fuel maps, etc.
Over 500 or 600 things that can be changed wit ha piggly back tuner. I have 3 1" thick note books with all the info I could dig up. Not well oginized somer apps not completely figuured out. Spent 6 months compiling info figuring out what did what. Bottom line a carb is easyer cheeper to set up than a EFI system that dosent use a Wide Band O2 sensor. I would only go crazy with EFI again with a Hilborn individual TB set up.Scars are tatoos of the fearless
Originally posted by 90ltd View PostWhat I had done to the car: ho throttle body, bored out egr spacer bored out lopo upper, dual 2.5 exhaust no mufflers, no ac nor air pump. I plan to port runners 1 5 7, install slightly modified lincoln logs. On the running lean issue i wanna try 15 pound injectors from 4.9 i6 truck.
On the on the ho swap: right now I'm pretty close to gt output and explorer engine has the same torque so no go. One thing i noticed is that almost all parts add horsepower but not torque. __2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
