Coolant Loss V2
    Unless you are buying real shit caps they last longer than that. I have OEM caps in for years......
      "Made in Mexico"....hmm...
        Not sure of the OEM source but I would try a Motorcraft cap and see how long it lasts. If your cooling system is intact (no warping around the area under the cap) and not a "lumpy" coolant system you should be fine!!
          Great, Glad it was an easy solution.
            Me too.
            Now, to investigate why the suspension creaks whenever the car shifts weight....
              spring seats worn out... body bushings shot... yadda yadda. as long as stuffs not rusting off... meh.
                *makes list*
