bizarre issue.. won't stay running..
    Yep, it's called the replace engine light for a reason.
    Replace...Engine that sounds menacing.. if thats the case i'll call a scrapper to come get it.. shame body and interior are gorgeous.. :/
      I would do whatever I could (within financial reason) to save it before I junked it! Bobby
        If it's headed for the scrappers, I bet you could sell parts or the whole thing to someone here if it's as clean as you say it is. I am on the lookout for some nice clean front (sans vent window) and rear passenger doors. Your location would be a big factor, for me, anyway.
          Do some diagnostic work first and find out what happened. It may not be the end of it, but unless you look at it you'll never know.
            Ltd88, where are you located. We may have a member near you. If you are anywhere in central Ky, I'll see if I can swing by and give you a hand. One of us might just be interested in the car itself if you decide to stop fooling with it.
            Axle codes
            Open/Lock/Ratio #
            G / H / 2.26
            B / C / 2.47
            8 / M / 2.73
            7 / - / 3.07
            Y / Z / 3.08
            4 / D / 3.42
            F / R / 3.45
            5 / E / 3.27
            6 / W / 3.73
            2 / K / 3.55
            A / - / 3.63
            J / - / 3.85
              windber,pa
                gonna swap distributors tomorrow and run a compression test, will post back with numbers.
                  suspect the ignition module if it got really hot like it sounds like it did.
                  even if the engine indeed has low oil pressure at idle and the light flickers, they will run a long long time like that as long as you keep oil in it
                  if the engine is toast and the body and interior are real nice, all the more reason to swap in a 5.0 HO! still cheaper than someone elses used car in most cases.
                    Swapped distributor. She starts but very rough. Compression test. Drivers side front to rear. 110 90 30 0 passenger front to rear 120 110 100 110
                      That seems pretty low all around but all compression testers are different. 3 & 4 are certainly unhappy. Normally I'd say throw a headgasket on it since it appears to be obviously leaking between the cylinders, but from everything else you've said about the engine I'd be looking for a Explorer long block to drop in.
                        That 0 on the rear cyl on drivers side worries me.
                          explorer long block?
                            yes!
                            1996 to 2001 ford explorers and mercury mountaineers were available with the 5.0 engine.
                            1996 engines have the gt40 heads.......these will work with stock manifolds also 1996 has the intake manifold with internal egr that we like to use here.
                            1997 to 2001 engines have gt40p heads........great heads but because of the spark plug angle needs ford racing stainless steel headers........dec 97-01 intake manifolds have external egr.......some of the 97 production explorers up to sometime in dec 97 have the intake with internal egr.
                              have to see if i can find any for a good price? will i notice any econemy or power differences?
                                100+ more HP with supporting mods.
