cant find it anywhere for some reason.
anyone know the GVW of a 1989 townie?
http://lincolntowncar.org/tech/tech1989.html
Best I can come up with for you. I do believe the GVWR numbers are on the door sticker tho.86 Lincoln Town Car (Galactica).
Do you want the weight of the car when empty or the total weight of the car with its maximum load?
The GVWR on the door sticker is the max weight including load.
The weight given in the link above is likely with no fuel, no oil, no antifreeze, as my Grand Marquis weighs about that much on the scale at the race track, and a TC ought to be at least 100lb heaver, I reckon.FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
Junkyard HO, MSD wires, stock Mustang headers, off-road H, Hemi Super Turbos. 3.55 trac loc, HO governor and servo in stock rebuilt AOD. 3-row rad, air pump delete, cop rear bar, wagon rear springs, 93 CV rear discs, 98-02 Grand Marquis wheels, Class 3 hitch, aluminum space-saver spare.
Coming soon: 98-02 front brakes, cop springs, Monroe cop shocks, 96 Cobra wheels w/255/50/17. Better yet, need a nice wagon to put all that stuff in.
