I didnt figure it would do much. A hot air intake would do about as much I expect. None of that stuff does anything useful for performance though.
EGR cooler line delete?
Just to clarify, it sounds like I have two options:
1) remove the T from the heater hose entirely and then plug the manifold
2) get a new smaller hose that goes from the manifold to the T in the heater hose (and just bypass the EGR cooler)
Since I can't really see/tell where the leak is coming from (just "back there") I'm leaning toward #1 in order to delete all of that stuff by just replacing the heater hose.
Thanks (as always) for the input.
if you're unhooking the cooler, I'd eliminate all of the hoses and whatnot.86 Lincoln Town Car (Galactica).
i pulled the back of the EGR cooler off so i could access the return line to the manifold (tight fit back there on the CFI)... now that i could see it, i could tell my leak was coming from there -- but the question was, was it the hose fitting or the nipple/connector? i had planned to just remove it all, but that nipple wasn't gonna budge easily, and i was afraid i'd jack it or the manifold up if i forced it (a bit corroded from leaking so much). so i ended up just replacing the hose and the clamp (a much easier fix), and keeping my fingers crossed. so far, so good. (knock on wood)
Nice! I've been thinking that lines leaking on my car as well but haven't had a chance to look yet.
*Knocks on wood* Hopefully the quick and easy fix does it!
Originally posted by porschpow View Postwhat is the purpose of the stupid cooler lines running through the throttle body?Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
