Over the winter, the Sand Box decided to develop a leak in the radiator at the crimp between the core and passenger side plastic tank. Does anyone know for sure if the towing package cars had the same radiator as the standard one or not? I know the water pump is the HD version, but have not found conclusive info about the rad. Rock Auto does list a rad for "w/5.0L, w/towing package" but doesn't even state the manufacturer. The listing for wagons is the same as the sedan. I have the good used rad out of my Tudor which will likely be replaced with a bigger aftermarket one, but if it is not equivalent to a towing package rad then I'd rather source the correct version.
Same radiator on '87 towing package vs. standard?
RyPow
1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
2007 Lincoln Town Car Signature Limited, 102k, daily driver
2006 Mercury Grand Marquis LS, 115k, winter beats
1977 Lincoln Continental Town Car, 42k
2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
2015 Toyota RAV4 XLE AWD (better half's)Tags: None
I stopped by my usual parts store today, they only list one style of rad for 5.0L cars. I checked Rock Auto for a 351 rad, and there are many more listings including 2- and 3-row. I assume these are fleet/police replacements. Has anyone had experience with the Spectra CU547 or CU552? I could see myself going for the CU547 (2-row) as an upgrade, since there isn't much of a price premium over the CU227 (listing for 5.0L).Last edited by RyPow; 04-30-2015, 04:14 PM.RyPow
The 351 radiator fits, but you need the upper radiator hose for the same vehicle. You will probably also need to modify the upper radiator clamps and the rubber block it sits into for the rad to sit right.86 Lincoln Town Car (Galactica).
+1 will need to modify the passenger side rad bracket and need the top rad hose for a 351. 3-core will need custom brackets both sides.
Originally posted by TecNickal View PostWhen I looked at a tow package car I found the radiator is the same size.
Originally posted by gadget73 View PostThe 351 radiator fits, but you need the upper radiator hose for the same vehicle. You will probably also need to modify the upper radiator clamps and the rubber block it sits into for the rad to sit right.Originally posted by sly View Post+1 will need to modify the passenger side rad bracket and need the top rad hose for a 351. 3-core will need custom brackets both sides.RyPow
