Filler Neck Grommet
    Filler Neck Grommet
    Forgot the last step to completing the fuel system for the CV. I was trying to get the filler neck pipe into the grommet, but it's being a pain. Do you guys have any tips on getting that filler pipe into the grommet? Cutting, Crisco?
    Petroleum jelly is what I used. Slid right in.
      I bet if it had hair around it you'd get it .
      1991 Mercury Grand Marquis LE SOLD
      1972 Ford F100 Custom - 5.9 - Stock
      2011 Ford Fusion SE - 2.5 - Stock
      2018 Toyota Highlander XLE
        They usually slide right in for me.
        How about using a little WD40 or PB Blaster?
          Clean any rust and dirt off the fill neck first, then pretty much any lubricant that will go away in gasoline will get it done. No KY, its not that sort of orifice.
            Awesome! Thanks guys. No, I don't have those types of relationships with my vehicles anymore. Too much heartbreak and tears! :-(
