Need more help...
    Does it give any codes? Both stored and engine running.
      Put car back together with new fuel regulator and cleaned injectors, nothing changed idle is a little bit smoother, otherwise I have not a fucking clue what's wrong at this point, I'll pull codes again tomorrow and see what comes up but I've done all the basics, new fuel pump. New tfi. New coil. New dizzy. New fuel filter and tank and regulator. At this point I'm ready to rip off the efi and put a Holley on it, if anyone has any idea what it could be please help I'm at a complete lost at this point
        Forgive me if this has been covered but have we checked plugs and wires? How about plugged cats? Does it run hot? Compression test? How is oil consumption? Lots of factors could play here so don't give up on her yet. I would say fuel delivery is solid and almost all ignition has been gone through, so we move onto the next system once that has been exhausted. Fire it up and feel the exhaust exiting the pipe(s). If you barely get anything, could be plugged cats. If you're sucking oil the back 2 spark plugs may be fouled. Try all the easy cheap things to check first.
          I can say from personal experience if the rear plugs are fouled it will still have power. Have you played with the MAP sensor yet? Verify you don't have vacuum leaks going to that or anywhere else? Have you tried swapping the computer? I know that's a stretch but what the hell eh?
            Plugs and wires are new about 1k ago haven't had a problem with them woulndt of just gone while driving and there is no cats, where would oil be sucking in? Yes I tried a different MAP and it didn't change, no vacuum leaks, I could try a different computer I might be able to find one from a friend I don't even know where they are on the car
              Yeah, verify bad parts with known good parts. It was certainly nice having Ashley's TC around so we could test between the two when things went south. Anyhow, oil would be getting sucked in through the valve seals, which harden up over time and allow oil to come through and get on the spark plug, fouling it out. Computer is under the driver's side dashboard on the firewall, behind the parking brake. You can see where it goes if you look under the hood and follow the big wiring harness along the driver's side fender to the firewall.
                does the car go thru antifreeze?.......if so, check and make sure its not leaking at the throttle body into the intake, that can make it run kinda crappy too.....
                I'm not completely oblivious to reality, I just choose to reject it when it doesn't line up with my opinions. (thanx Thain!)
                  Antifreeze and oil are both full and haven't gone down, seems like something else since as it happened i was going down the road and just started getting worse and worse, dead miss like someone was unplugging something
                    If you were local I'd let you try my spare computer to see if anything changes.
                      Where are you located?
                        Conneticut, I do have a computer I could try, I just don't get why it would give up randomly driving but still idle okay but not want to rev up
                          Idle is smoother a little bit more revs but still will not rev up, just pops and bogs, still out of ideas
                            Got high rpms but still bogging so not sure back to doing the same thing
                                Codes were 63 34 14
