changing differential oil
    Originally posted by 88grandmarq
    1 grunt on the grunt-O-meter
    :lol: Great scale!
      Thanks for the info, guys. I really appreciate it.
      Ran down to CarQuest and picked up 2 qts. of 80w-90 and a tube of blue RTV silicone (boy, does that bring back memories . . . . :drug: ). Also grabbed a tube of Sil-Glyde lube. Gonna try it on the vertical window tracks so those big windows move a little easier.
        I actually prefer the OEM black silicone, but blue works.
        Remember, you want a thin bead of silicone (about 1/8") let it partly cure, usually about 20-25 mins before you put the cover back on.
          :lol: Great scale!
          German specs can also apply. Gut en Tight
            Sil-Glyde lube? That sounds like something better suited to a more intimate environment than this.
              I take it that the easiest way is to apply the silicone to the differential, not the cover.
              How do I seal around the bolt holes? Any certain way or just go completely around 'em?
                I went completely around each bolt whole, just for good measure, though running on just the inside or the outside I don't think would cause an issue.
                  i like to use a gasket when possible, but silicone works just as well
