Mine are down below the radio, honestly they are not visible when driving. I could lose oil pressure and I wouldn't know it. thats actually why I modified my sending unit extension and put the idiot light switch back in. At least I might see the light if something tragic happens.
My 88 mgm
My 88 mgm
Update so far trimmed the lower gauge pod almost fits perfect under the ash tray
Also replace all 6 interior speaker had to trim the door speaker hole a bit, and put some dynamat around speaker. replaced the front door
Also here’s a better picture of the Adtr rear control arm with my exhaust and aluminum drive shaft installed
And my rear disc conversion I been trying to do I started buying parts rear disc (finally)
My new diff cover. Carbon clutches are coming Tuesday. Hopefully next week I will order the gears and rebuild kit for the rearend
When it’s done it will look like this.
Sent from my iPhone using TapatalkLast edited by Elias; 04-02-2020, 06:57 PM.
Nice!
Got a brand or part number on the gauge pod? How much modifying did you have to do?1990 Country Squire - under restoration
My 88 mgm
Originally posted by Tiggie View PostGot a brand or part number on the gauge pod? How much modifying did you have to do?
https://www.ebay.com/itm/Gauge-Pod-G...EAAOSwE-VehQgp
Sent from my iPhone using TapatalkLast edited by Elias; 04-03-2020, 01:16 PM.
Nice
I like it.~David~
Looks like it will be in better shape.
Question on the rear, Is that a 28 spline carrier?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Well while it was all torn apart I decided to go electric fans also lol
I ordered the Lmr contour fans with controller and went to town.
Spacing was almost perfect only thing I had to do was drill top mounting brackets a bit.
I wired the controller inside the glove box which I think came out great
Wired all relays to fuse box which includes high and low fans and also. Headlight relays
