^^^I would go with the pro products, that's the intake i have. I'll say this though, you may want to run a spacer on it to allow you better access to things underneath. Far as the Megasquirt goes, they make the PnP, which is just what it sounds like. Plugs into the stock harness. Depending on who you buy it from, they will set you up with a base tune based on setup info you give them. Then you can datalog and report back to them and they'll modify your tune, free. This is sounding ideal to me because i don't have the time to dick around tuning this, not to mention i really don't know what i'm doing. Megasquirt basically converts you top SD unless you really want to run a MAF, but the consensus is that it's easier without it. Certain models of the MS also have an auto-tune feature, although i'm not sure how good it is.
Parts pile for future 351 transplant for my '86
Originally posted by sick88tbird View PostNot a concern with the Professional Products 351 upper/lower
was not aware they did a plug and play for the mega squirt in our application, that greatly increases the wantCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
Originally posted by marquis_82_withneons View Postis this the intake thats listed as "typhoon"? after looking it up it lists 302 specifically. i imagine it will fit the 351 right?
351's use wider lower intakes. One cannot swap a lower intake from a 302 to a 351 vice verse.~David~
Just need to confirm the height. If its not taller than the Lightning piece, you're good to go. 351's are taller so the intake has to be shorter for clearance under a stock hood.86 Lincoln Town Car (Galactica).
Knucklehead, do you have tall valve covers or something? I have plenty of room on mine with H.O. valve covers. I can even change gaskets without disturbing the upper plenum.Last edited by sick88tbird; 09-17-2019, 10:16 AM.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
With the lopo, tall valve covers (Ford Racing EFI) were a problem without a spacer; oil fill tube would hit the bottom of the upper intake. Had I gotten a spacer those many moons ago; I would still have those valve covers.
My current problem is the aftermarket heads and the current Ford Racing valve covers hitting the wiper motor cover. I had to cut the cover to get the 351W to fit. I will figure out what to do with the wipers at a later time.
should have changed the valve covers rather than hack at the wiper box. Valve covers are easier to source. The factory 351 cars went together and I've seen non-factory ones assembled too.86 Lincoln Town Car (Galactica).
Originally posted by knucklehead0202 View Post^^^I would go with the pro products, that's the intake i have. I'll say this though, you may want to run a spacer on it to allow you better access to things underneath. Far as the Megasquirt goes, they make the PnP, which is just what it sounds like. Plugs into the stock harness. Depending on who you buy it from, they will set you up with a base tune based on setup info you give them. Then you can datalog and report back to them and they'll modify your tune, free. This is sounding ideal to me because i don't have the time to dick around tuning this, not to mention i really don't know what i'm doing. Megasquirt basically converts you top SD unless you really want to run a MAF, but the consensus is that it's easier without it. Certain models of the MS also have an auto-tune feature, although i'm not sure how good it is.
So...with the PP intake upper and lower.... and the MS... this sounds... obviously the way to go.
i don't have the time to dick around tuning this, not to mention i really don't know what i'm doing is EXACTLY me.All FORD All The Time
Originally posted by clutch47 View PostThis piques my interest. I really have no ill will against SD and I find it amusing after all these years a lot of new cars are SD.
i don't have the time to dick around tuning this, not to mention i really don't know what i'm doing is EXACTLY me.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Originally posted by 86VickyLX View PostI've done the 351w in a coupe thing. My 86 Two door from Texas has a 94 roller block 351 in it now.
I'm a power addict but in this car... I don't want to give away the easy to drive comfortable demeanor of it.
I really thing 350 hp and 325 Tq would be cake and make it the perfect street box for me without making it too racy.
It's already got the 3.73 and traction loc...All FORD All The Time
Originally posted by sick88tbird View PostAftermarket SD systems are great, I just didn’t want to see you go down the Ford SD rabbit-hole! Lol
BUT... this car is no nice, I can't bring myself to cut it up...even in the wiring department.
I see you have done the same. 351 in the coupe.
Any advice.??Last edited by clutch47; 09-17-2019, 05:09 PM.All FORD All The Time
Originally posted by clutch47 View PostI'm so enamored with a properly tuned carburetor....that I've never subscribed to EFI.
Any advice.??'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Originally posted by sick88tbird View PostNot particularly...it’s pretty straight forward. It’s nice to do a port fuel injection setup on a car that already came with it...mine was a CFI car. Basically, keep stock-ish valve covers, the Typhoon intake fits nicely(with a decent throttle body). Some throttle bodies have a goofy adapter looking thing to mount the TPS sensor and that WILL cause a clearance issue. Mustang H or X-pipe need to be modified to actually fit. Some people say they “fit fine”...yeah, only if you like your car looking like the exhaust may fall off at any given moment. I’m in the process of making a set of long-tube headers work on a panther, but it most likely won’t apply to 351w swapped cars.
I've got Magnaflows on the car with the stock cats and it's quiet but sounds very good. No H pipe at all. Nice drone around 2K I think. Best get my damn tach on there..
I'm debating leaving the cats on it... how much louder ya think it'll get without them?All FORD All The Time
Originally posted by sick88tbird View PostYes, but you have to buy the upper and lower separately. You’ll have to look up the lower for a 351w, the uppers are the same.
