Finally Got the Work Started on the '79
    how much the harness helps really seems to depend on the specifics. I got better than 2v on my Towncar and about 1.6 on the Continental. Made a huge difference. If your wiring isn't as lossy it won't matter as much. It never did anything on the Mark VII other than cause me trouble. After burning out several relays for less than 0.2 volts of improvement I trashed the harness.
    I missed this post.
    I'm sure I've got voltage loss issues. Everyone that has done the swap on their box noticed an improvement so I can't imagine my car is exempt. Oh, well yeah, I'd trash it too in that case. I hate the idea of doing modifications only to have to undo them. Such is life though. Theres not much like making a modification you didn't expect to do much only to have significant gains come your way from them though. I like pleasant surprises.
      I'm held up on DMV closures too. Towncar has been expired since November. Wanted to swap it to a historic plate because its much cheaper but then the world went nuts.
      Illinois has "antique vehicle" plates which are cheap, but super restrictive. No idea how strongly they're enforced, but I like to drive my cars around without worrying about restrictions. Not like I am going to drive my 30+ year old vehicles every day everywhere I go, but who knows.
      Sent from my VS988 using Tapatalk
      1978 Ford LTD wagon, 351M
      1979 Mercury Marquis, 351W
      1987 Ford F-250 HD 4x4, 460, 4-speed, reg cab full bed
      2003 Mercury Marauder, 4.6L DOHC, JLT CAI, 4.10 gears, J-mod, custom tune
        I missed this post.
        The nice thing with the headlight harnesses is that they're easy to install and remove. All you really do is plug them into a headlight socket, and also connect to power and ground. Made a nice difference in my 2003 Marauder.
          You can get the Expanded Use antique plates. I have them on my ‘85. I think the renewal is $50/year and the car can be used without any silly restrictions from April through October.
            i wish NY offered something like that, the expanded use option, but NY sucks. They even specifically prohibit insurers from offering winter garaged vehicle rates.
              This is the sum total of what NJ MVC has to say about historic plates.
              Vehicle requirements:•
              Owned as a collector’s item•
              Used solely for exhibition or educational purposes•
              Cannot be altered from the manufacturer’s original design in any way
              Equipped for legal operation on NJ roadways
              somewhere in there it says it has to be at least 25 years old too.
              Strictly speaking the Towncar doesn't actually qualify but I'd like to see someone figure out why from the 2 pictures I have to provide of the car for the application. They don't actually define what "exhibition" is either, so I figure I'm exhibiting it by displaying the vehicle in it's native environment, driving down the road.
                Exactly. "exhibition" is a huge gray area prime for exploitation. In MI, it strictly states that you must only be driving the car to and from a show or parade so it's pretty easy to get burned by that. I put those plates on my Fury and got burned mid road trip.
                  Virginia changed the law a few years ago to say car shows, maintenance, parts runs, and pleasure use up to 250 miles a day.
                  Basically, I can’t drive it to work. I suspect it will change again since I do see some abuse of it.
                    This is pretty much how IL handles it, too. Since I like to go cruising and sometimes drive the cars to work, it's a pretty crappy option.
                      On a separate note, I've been trying to look up some replacement crank pulley bolts, and I can't find what I need. I get the right thread and all, but they're for applications without a spacer between the pulley and balancer, they're too short. The only set I found that are an acceptable length are for GM engines, have a different thread. I wanted to go with an ARP set, since they should stay nice for a long time, but they don't appear to have what I need. Any clue as to where I can get what I need? 'm guessing I might just need to get some generic 3/8-16 bolts, but hopefully in a long-lasting finish that protects against corrosion.
                        there isn't a spacer on later ones, but I've never fooled with a 79. Can you tell what grade they are by the markings on the head? I'd figure at least a grade 5. McMaster-Carr will have them if needed. Can get whatever finish or material you like, probably including stainless.
                        I'm a bit of a McMaster fanboy. Of all the companies I order crap from at work, they're probably my favorite.
                          Well, there isn't a factory spacer. All of the aftermarket options are pretty much the same size and I needed a spacer to increase the depth enough to get the pulley into the right spot. I also don't think the factory pulley would sit flush against an aftermarket style balancer anyway. Probably wouldn't be an issue if I installed a full accessory and belt system from someone like CVF Racing. Planning on doing that eventually to at least one of my old Fords. They have something for all three of the different motors in my carbed rides: 351W, 351M, 460.
                          I'd assume the bolts are at least grade 5, as well. I'll take a look at McMaster-Carr. I haven't had dealings with them in about a decade. Used to order stuff from them in my old job, and also drop off a diesel trailered air compressor over there for annual service. Glad to be done hauling with a pintle hitch, for sure.
                            whats different about the aftermarket balancer vs the stock one that needs a spacer added? bit confused here.
                              The aftermarket isn't as deep as the factory. Without a spacer the pulley wouldn't be in alignment with the others. I forget what the overall depth is of either balancer, but I needed a 0.875" spacer. I only saw one balancer that didn't require a spacer, but I'll be damned if I'm going to put any Dorman parts on a car if there are other options available.
                                I thought Ford used basically the same balancer on everything from the late 60s through the 90s on the 351, or at least the spacing between the pulley flange and the front of the crank was the same.
