Are you guys running a restrictor in the inlet line? Im pretty sure its the passenger side line, correct?
heater core restrictor
The line from the pipe near the thermostat is the "input" side of the heater core. The one that goes back to the water pump is the "output". So typically this should be the driver side of the heater core, but follow the hoses. That will give you the correct one. They can flow either way.
Originally posted by sly View PostThe line from the pipe near the thermostat is the "input" side of the heater core. The one that goes back to the water pump is the "output". So typically this should be the driver side of the heater core, but follow the hoses. That will give you the correct one. They can flow either way.1987 CV LX 5.0
I'm using a washer on mine. This is the official item
https://lmr.com/item/LRS-18599A/79-0...low-Restrictor86 Lincoln Town Car (Galactica).
I am running the official item.~David~
I’ve got a 13mm in mine.
My Cars:
no, it just makes the core less likely to pop if you wind the engine up a bunch.86 Lincoln Town Car (Galactica).
Originally posted by WagonMan View PostDoes a restrictor give you more heat? I put a new heater core in my 90 without ATC and I barely get any heat out of it. Even with the 195 degree thermostat. WagonMan
Were your blend and mode door ok in the hvac box?1987 CV LX 5.0
Originally posted by mcb82gt View PostSly, are you running a restrictor? Think ill just jam a 1/2 socket in there and hose clamp it.
Originally posted by sly View PostI was using the flush T as a restrictor until I put in the coolant filter. That's a good restrictor too.1987 CV LX 5.0
I used the flush T on the heater core input line and just ran hoses from that to the filter (in from engine, out to heater core). I used the following item from Amazon to do it and mounted it on a makeshift bracket I made.
Filter mount:
https://www.amazon.com/gp/product/B000CSINYU/
Filter:
https://www.amazon.com/gp/product/B0014B8S8A/
Reader's Rides post:
Wife's car: http://www.grandmarq.net/vb/showthre...l=1#post806998
The cake: http://www.grandmarq.net/vb/showthre...l=1#post811320
Originally posted by sly View PostI used the flush T on the heater core input line and just ran hoses from that to the filter (in from engine, out to heater core). I used the following item from Amazon to do it and mounted it on a makeshift bracket I made.
Filter mount:
Filter:
The cake: http://www.grandmarq.net/vb/showthre...l=1#post8113201987 CV LX 5.0
He went all "overkill is underrated" on it.~David~
Originally posted by 87gtVIC View PostHe went all "overkill is underrated" on it.
I put a "small diesel" style setup on my cars.
That said, my wife's car was really bad with the chunks and debris in the coolant system and the first filter clogged up in 2 weeks which was just about 50 miles of driving. The next one about 2 months. Then I managed to last until oil changes after that.
