Cooling problems
    Originally posted by 91merc View Post
    Well I finally got my hands on some thermocure and that stuff WORKS, I was able to run 70 down the highway for 15 miles and not overheat, and when I got to work I could hold my hand on the radiator. Thanks for the suggestion Kodachrome Wolf!
    Hell yeah!
    I like stuff that actually works, simply because I hate having to constantly having to deal with a repeat issue. Just keep an eye on the coolant condition/color shift over a few days. In the car I treated, the coolant shifted from green to black. After rinsing everything well a few times, it finally stayed the proper color.
    My Cars:
      I have since developed a timing cover gasket leak
      Should've replaced it when I did the water pump 1k ago
        What a difference in that coolant! Wow
          Switch to Evan's coolant. It's a process but I'd wager it won't leak again after that and you won't blow out any more heater cores.
            Have seen too many stories of much higher engine temps with Evans. To be safe (and save a lot of money) I'll stick to conventional coolant and flush on a timely basis. Probably works for some folks but I'l pass!
            P.S. I am allowing for using the product correctly and not leaving more than say 3% water in the system.
              I can only report my experience with Evans. The temp runs about 1/2 the width of the pointer higher on the Marauder. Can just barely discern it. It has never gotten any higher than that. I like the really low operating pressure. Evans has checked the coolant for condition every few years for me and so far so good.
              if I had realized I was going to keep the TC as long as I have I would have converted that as well.
              Evans is only worth it imnsho if you plan on keeping the car or it is a special collectable that has a sealed system. Open systems are not ideal for Evans because it is hygroscopic though I have no idea how long it would take to absorb enough water to require replacement or simmering to remove it.
                I like the idea of low operating pressure also. Don't like that it is hygroscopic, didn't know that..
