I'm assembling everything for my upper intake to ease the actual labor cost for my HO conversion. The main parts are the upper intake, EGR spacer, EGR valve, TPS, IAC and throttle body. Where can I find all of the gaskets and bolts required?
Gaskets and bolts (upper intake).
I have the stock upper plenum bolts, if you need them. I'm not using them since I'm running a 1" phenolic spacer.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
I'm going to be running a spacer. I haven't decided which spacer to run, but most of them come with bolts. What bolts or studs are needed for the EGR spacer and TB? (I remember 13mm studs for some reason).
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
I used the FRPP 1/2" spacer, and I recommend it.
It is M9486A51, and is $40.70 from:
I did buy one on ebay first, which cost less than $30, but didn't care for its quality, so bought the FRPP part.
HO with Explorer Cam, Electric Fan, Cop Sway Bars, Dual exhaust with no mufflers, 15x7" American Racing; 215/70R15's front, 255/60R15's rear, 3.55's with Trak-Lok.
The studs for the EGR spacer and throttle body should be in the intake already. If not, just steal the ones from your lopo intake. Gaskets can be had at any auto parts store with half an ounce of common sense. Just ask for the gaskets for like a 1988 Mark VII, that way you get the correct throttle body and EGR spacer gaskets for the HO upper.86 Lincoln Town Car (Galactica).
Did the FRPP piece come with the right bolts? The TrickFlow spacer I ordered said you need to get two longer bolts if using the Explorer intake. I'm like, "Why didn't you fucking include them?!"2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Yes, it came with the rights bolts - but I used a HO upper.
I can't comment on the applicability to the explorer upper, as I just don't know that answer!
Fel pro parts:
ms93334 lower intake set. has the 2 head to intake gaskets, 2 rubber end gaskets, distributor O ring, lower to upper intake gasket, IAC gasket (no idea why)
72543 upper intake to EGR spacer gasket
70262 EGR spacer to throttle body gasket
70020 EGR valve to EGR spacer gasket (optional)86 Lincoln Town Car (Galactica).
