Power stroke
    Oh dude...stretched towncar on a stretched Excursion frame, with a lift kit.
    Nick
    88 Colony Park LS
      There's a 7.3 powerstroke near Raleigh if anyone is interested.
        It's a great idea if you don't mind paying over $300 for valve cover gaskets.
