I didn't have to change the wiring for it. But it's run off of a tempreture switch to a relay, and it is on key power, so it doesn't run when I walk away always hate those.
New electric radiator fan.
My 98 fan is way bigger. I got pics but the stupid camera doesn't talk to XP, and the printer with the memory card reader is unhooked because we're re-doing the office. The top of the fan shroud measures 8 3/4" deep tho If I lay it on the ground, the back of the motor is 9" from floor level. Not sure I can get that in there without water pump clearance issues.Originally posted by DuceAnAHalfIm using a fan off a 95 Pi I believe the fan is the same as the 02.
Thats wierd, the one on my 97 is the same as that one, as is the other fan i got. These fans are about 20" in diameter and pull less than 25 amps.Originally posted by gadget73My 98 fan is way bigger. I got pics but the stupid camera doesn't talk to XP, and the printer with the memory card reader is unhooked because we're re-doing the office. The top of the fan shroud measures 8 3/4" deep tho If I lay it on the ground, the back of the motor is 9" from floor level. Not sure I can get that in there without water pump clearance issues.http://secondhandracing.com/Home.aspx
