347 stroker
(here is some specs on a motor, i was wondering what you all think?)
Block:
Hand picked seasoned blocks bored .040 over
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
New SCAT cast crankshaft
New SCAT rods w/ 150,000 psi bolts
Keith Black Hypereutectic pistons
Hastings Moly rings
Balanced rotating assembly
Melling high volume oil pump
Flat tappet hydraulic lifter camshaft
Heavy duty double roller timing set
Cylinder Heads:
Modified Ford cast iron heads
Hardened retainers and springs
2.02 swirl polished intake valves
1.60 swirl polished exhaust valves
Hardened push rods
A Ton Of Extras:
Professional Products dual plane satin aluminum intake manifold
9.5 to 1 compression
Signature series aluminum valve covers
Brass freeze plugs
Critical Specs:
Horsepower:
330
Torque:
380
Block:
Rotating Assembly:
Hastings Moly rings
Cylinder Heads:
Hardened push rods
A Ton Of Extras:
Brass freeze plugs
Critical Specs:
Horsepower:
330
Torque:
380
