OK, make sure I'm doing this right.
Stock pushrod length= 6.270
Preload= .030
Awhile back I did a test fit of the adj rockers. Not enough adjustment. So, from that rocker I figured that the pushrod needs to be ~.20" or so longer to put the pushrod cup in a good spot in the rocker.(I have the adjustable pedestal ones, the cup is hieght adjustable)
So, I will need a pushrod that is 6.270+.030+.2= 6.500" Correct?
The least expensive pushrods that were the closest in length were 6.480 for 80 bucks. There were 6.500" exactly. The least expensive 6.500 was 87 bucks...Meh 6 bucks....
Preload= .030
