I was wondering if these newer style injectors will work on my old fuel rail?
Injector Styles
Those will not work. They have a smaller diameter at the top. The 4 spray design you are talking about does not look any different from the outside. These are the ones I had for a bit that were bad. They are the 4 spray design, notice they look the same as what you have. Personaly I believe the conical is better, and so did ford, as ford went back to the conical spray.
This is the only difference between the two designs.
4 Spray:
