Intake
    Intake
    What size intake should I run now. I have a 3 right now. I went to look for a new filter and the guy says that 3 inch is small. 3 1/2 -4 inch is normal. Now looking for one it is hard to find 3 inch. Is it too small or what?
    Fucking intake kits cost alot of money. 150 for what. A filter and a pipe.
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
    go to your local autozone and get the universal intake parts and make your own, or use aluminum tubing from somewhere, you can get all the silicone adapters and filters etc. at advance autoparts or sutozone, i find autozone usually has every part youll ever need for building an intake
      Not any autozone around here. I don't have an advanced around here either.
      4 Door Muscle
      Supermotors
        Check around some of the import forums and import parts websites. There are a ton of companies that make cold air intakes. I paid $90 for my complete cold air intake for my 93 Eagle Talon from Cosmoracing.com. It worked very well and you can find those intakes even cheaper than that now.
        Associated Panthers:
          http://www.fordmuscle.com/archives/2...ir/index.shtml
          It is pretty conclusive that the aftermarket conical filter, relocated to the fenderwell, offers absolutely no performance advantage over the stock air box fitted with a clean K&N panel filter.
            Blackhawk, what's the point of running a 100mm (4") pipe when your TB, EGR spacer, and intake manifold still have the 60mm opening?
              Well I was going to get it because I have plans on modding everything. It's best to have everything before hand. I think I'll just buy a cheap paper filter for my 3 inch now and get something better when I actually do the motor.
              4 Door Muscle
              Supermotors
                Sounds like a plan. And stock lopo TB size is 50mm. Pretty tiny.
                  dont waste your money.......teh 50mm tb is a bottleneck
                    I'm just going to keep the 3 inch. It's an MAF pipe though. Anyone have a better suggetion than this here garden hose?
                    Anways I think cold air intakes are over rated. The main thing you should worry about is the Manifolds and TB. I guess 3 inch is big enough either way. Isn't it like 75mm anyways.
                    I got this.
                    Product Style: Round Straight Universal Air Filter
                    Flange Inside Diameter: 3 in (76 mm)
                    Flange Length: 0.625 in (16 mm)
                    Flange Type: Centered
                    Height: 6.5 in (165 mm)
                    Outside Diameter: 5 in (127 mm))
                    4 Door Muscle
                    Supermotors
                      that's fine
                        Use a rubber heater pipe cap over that fitting. It'll look a bit better. They're in the help section usually.
                          Walmart oil filter? :nonono:
                            The is old. That is from when my dad did my last oil change. Motorcraft is in there now. FL-1A
                            4 Door Muscle
                            Supermotors
                              FL-1HP for me bitches!
