The merc just got a valve tap on the passenger side head, its not too bad but you can hear it at idle. It sounds like a loose rocker at higher rpms, but I don't know if they are adjustable or not. I didn't really notice it before I removed the smog pump though, but the pump was about to seize though. I removed the pump, plugged all the vacumm lines not in use by it and left the belt for the AC off also.
Should I run rislone or an oil stabilizer the next time I change the oil. I had pretty good results with it in my truck, but I ran 20w50 in it also.
