tt 5.0
    tt 5.0
    if your too lazy to read this long-ass post i italicized my questions
    well there was a slight alteration to the tt 5.0 concept, instead of going into the lincoln, it's going into a 68 mustang me and my dad are going to build next summer (he's building a model "A" this summer). It should be happier in there anyways. For now, im just going to fantasize about a Y-block for the lincoln in the semi-distant future while it lives as an every-day driver.
    the real reason i posted this is because i can't find shit for turbo 5.0, information. For most of the parts im just going as if i was bolting on a supercharger as information for that is relatively easy to find. to end a wordy post short what kind of cam do you guys think would be appropriate for this? were trying to get some serious ass-haul while still being at least 85% streetable. thats why the choice of turbos over the originally intended supercharger that was destined for that car.
    so far i've found a combo with:
    .25" 4340 forged stroker crank
    matching lightwieght forged i-beam rods
    forged inverted dome pistons
    roush 200 cylinder heads
    this would give me a base compression of 8.1:1
    which leads to problem #2
    i have no idea how much boost im going to get out of these (if you don't remember i was planing on using two turbos off of 2.3L fords)
    help would be appreciated
    HUH? where are you searching. There are TONS of info on a bunch of sites....
    turbomustangs.com, corral.net are two great sites for info.
    The stock HO cam works very well with turbos.
      thanks i suck at the search
        Do you have any information on the turbos that were in the 2.3L Mustang? Keep in mind that just because you're doubling the size of the engine, doesn't mean two turbos from an engine half the size will work perfectly.
        I live, breathe, and work with turbochargers everyday (mostly on diesels, but same difference) and I hoped to plug and chug some 302/351 engine data on the side. A co-worker has two project Mustangs (302) he's done. One is a twin turbo setup, the other is a massive single stage turbo on a hot 347 strokah engine. He's always a good person to ask questions to.
        ~Adam
        '85 2-Door Crown Victoria
        302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
        '04 Crown Victoria LX Sport, '02 Jeep Liberty
        '83 Suzuki GS 1100E Motorcycle[/color]
          The 2.3 turbos work, the hitachis are a bit small for a 302(87-88 turbocoupe), but will work-and spool really quickly. The .63 hot side T-3's are the better choice, and are easiy upgradeable. I had a Holset H1E for my project that got scrapped. Even 2 dodge 5.9 diesel hx35's work good in a TT setup, one can be used, if you don't want much HP...
