Hey ed, what is the weight of a 351C, compared to a 302?
Motor differences
I was doing a little digging and I came across one of my old threads. You guys cleared up some of my questions, but I still have a few questions:
From what I can tell, the 74 Torino/Montego 351C 4V heads are the best flowing stock heads. Are these heads difficult to find and/or expensive?
Are the valves/lifters the same as the 351W?
And, would these heads work on a 351W block?88 Town Car (wrecked, for sale)
Originally posted by 88VicFrom what I can tell, the 74 Torino/Montego 351C 4V heads are the best flowing stock heads. Are these heads difficult to find and/or expensive?
2V valves with 4V ports and a HUGE chamber. The valves are the same as 351M and 400 NOT 351W. Not the head you want to use for a Clevor build (351W block Cleveland heads).
They are not easy to find and not worth the cost.
http://www.pricemotorsport.com/ Sells everything you need to build a Clevor besides the block and heads.http://secondhandracing.com/Home.aspx
70-71 4v heads. Closed chambers, big valves and huge ports. You'll pay some $$$ for em. Not only that but you can guarantee you'll need to rebuild the heads cause they are so old. Its less hassle and cheaper just to buy aftermarket sbf heads instead of building a clevor. Prolly will make more power too.
All the other cleveland heads suck cept for the australian 2v heads. Theres a company reproducing those in aluminum now I think.
Originally posted by Mercmarquis70-71 4v heads. Closed chambers, big valves and huge ports. You'll pay some $$$ for em. Not only that but you can guarantee you'll need to rebuild the heads cause they are so old. Its less hassle and cheaper just to buy aftermarket sbf heads instead of building a clevor. Prolly will make more power too.
All the other cleveland heads suck cept for the australian 2v heads. Theres a company reproducing those in aluminum now I think.http://secondhandracing.com/Home.aspx
Oh cool, they did finally introduce those new heads. Now if someone starts making an aftermarket 351C block, it'll actually be practical to build a Cleveland motor in the future.
Of course, I remember seeing an article on the Edelbrock 351C heads before they were introduced .... seems the flow numbers weren't quite as stellar as you'd expect. Anyone happen to know which magazine it was in?2012 Mazda5 Touring | Finally working on the LTD again!
Regarding the Edelbrock heads, peak flow numbers do not always make the most power.
Regarding "All the other Cleveland heads suck", 351C 4V open chamber heads have the advantage of unshrouded valves. They were actually chosen over closed chamber heads back in the day for drag racing because of better flow. These days people are worrying about trying to run their cars on low octane fuel. A quench chamber with a dish in the piston will help prevent detonation with the lower octane.
Using a Cleveland type head on a Windsor block requires a special intake, and modifications to the engine block.
http://www.darkhorseracing.net/clevor_head_mod.htm
if you want to know the nitty gritty. For the work and expense involved, honestly you're better off with an aftermarket Windsor head. Probably will end up being cheaper than obtaining a reasonably rare 35 year old part and having it rebuilt and modified for use.86 Lincoln Town Car (Galactica).
Originally posted by turbo2256bI have a 351C 4 bolt block, a mech roller cam, open chamber heads, 12.5 to 1 forged pistons and other stuff for sale.
What are the specs on your cam? Are the pistons for open chamber? Do you have any intakes for sale?
Originally posted by MercracerDo you have any intakes for sale?2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cpA guy I know of might still have an Offy dual-port intake, I think an Edelbrock intake, and if I remember correctly, one set of quench heads and one of either two-barrel or police interceptor heads. I can find out if you're interested.
