What is the standard range for the coolant temp for 302's while running? Both the '88 GM and '89 CV run 190 - 200 deg. F. Is this normal for around town driving?
coolant temp - high?
mine runs around 200-205 with the AC on and 5 big guys in the car on a hot day. just me no ac like 1901989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
195 thermostat is stock, so 190-200 would be normal. Thats what mine runs when its full of water anyway. If you want to have fun, let it get nice and low and you can slam the guage.86 Lincoln Town Car (Galactica).
