Throwing Belts
ah, you're close....to bad I don't have the parts anymore. You could come up and pick them up. I work right in DC.
Close is correct. Arlington,VA
Thanks to everyone for all the help and suggestions.
Leave a comment:
no roller or sniffer testing here, only visual. You must be close to the DC area
Leave a comment:
Sounds like your garage is overly anal. I have no such issues here. They don't even open the hood on my car. I think they checked it for cats, but I'm not 100% sure of that. They stick it on a dyno and use the sniffer. As long as the sniffer is smelling roses, its all good.
Leave a comment:
Originally posted by Ivan DEmissions testing is once an year, right? Then hook up the damn thing for that one day, go get the testing done, then when you get home just take all the stuff out, it's like half an hour job.
Leave a comment:
Guest repliedWhat was this bolt's thread, 1/2? Go to the nearest hardware store and pick up some 1/2 flat washers and some 9/16 nuts, then slide the necessary amount of both between the smog pump and the engine block - there's your spacer, for less than a $1
Leave a comment:
The spacer is a bit around an inch. It's pretty easy to eyeball where the pulley needs to be for the belt to be aligned.
Leave a comment:
Guest repliedEmissions testing is once an year, right? Then hook up the damn thing for that one day, go get the testing done, then when you get home just take all the stuff out, it's like half an hour job.
Leave a comment:
Sadly, for the visual test in Virginia the emmisions tech has a checklist of stuff to look for (one of them being smog pump).
Leave a comment:
MD also has visual and the dyno/sniffer test. I've never failed the visual, even with most parts removed. My wagon is the first panther I've had that failed the sniffer..
Leave a comment:
Unfortunately, Virginia has both a visual and the dyno-roller/sniffer test.
The short belt solution has promise, but I prefer to tear this apart only one more time to fix this before summer. I barely have time to fix it at all.
Leave a comment:
Lincolnmania should have a few...I dropped a load of scrap at Skippy's friday and had a few smog setups in it...
Leave a comment:
Guest repliedYes, there is supposed to be a spacer there, I'll measure mine tonight - I have like three of them there, since I have no smog pump anymore, and I wanted to keep the bolt as an extra support for the tensioner plate. However I have a question for you - does your state have emissions testing, and if yes what kind (sniffer, visuals, both)? If you don't have emissions, or you do but it's only the sniffer machine and no visuals, you are fully able to get rid of the smog pump and all the hose mess to the right of the engine without jurting the emissioms one bit - you lose some weight, get some more space for changing sparkplugs, gain some HP (and maybe MPG), and don't need to worry about spacers and stuff like that. You need a #560K belt to bypass the smog pump, have a look at this thread for how to route it:
http://www.grandmarq.net/vb/showthread.php?t=8506
Leave a comment:
Leave a comment:
