I mentioned it in my intro post a while back but I've been working on a single turbo setup for my 81 LTD S for a couple years now. Last year has been working with a remote tuner to get it driving like stock. He did an amazing job. Starts with just a turn of the key in all weather. No bad behavior on the street. But you can't really tune WOT with just logs so I took it to a local shop a couple weeks ago to put it on the hub dyno. The remote tune was super safe clocking in at 425 hp at the wheels. I added boost duty cycle to the boost control but it wouldn't go above 15 psi. I actually had my extra wastegate springs with me but I forgot I had them. I added timing to the max load and rpm cells ending up at about an additional 5 degrees before the benefits started to diminish and I got worried about knock. That put it at 541.7 hp at the hubs. Figuring 10% drivetrain loss, that put it at 600 at the crank which was my goal. So we stopped there.
Since then I've built the knock circuit into the Megasquirt and added the controller and sensor. Didn't see any knock at max power so I've turned the boost up another couple psi. I probably need to stop there. Tire spin is an issue in first and second and it chirps pretty good into third. Don't really need more than that. Rather put AC back in it, get the interior done, and paint so I can cruise it around and hit up local car meets.
