Hey guys. I was just wondering on how big of a cam can I run in the 351 without changing the torque converter? I am planning on running gt40 heads on it and would like to have a bigger cam. I wasn't sure of what would be a good cam with the stock torque converter.
camshaft question
just be glad it's not an aero trans... the stock engine kills those converters. That was the first thing I had to fix on the 93 vic.
The 351 converter stalls even lower than the standard 302 converter. Its truly horrible.86 Lincoln Town Car (Galactica).
The aod has some differences. The shift arm on the tranny is different and the mustang has a higher shift governor. Other than that identical, I have a mustang tranny in my marquis. I'm just not sure what the differences between the aod and aode are, I would assume the convertors are interchangeable as long as you get one from a 5.0 but .......
We all know where assuming gets us.
'90 LX 5.0 mustang
Big plans
Originally posted by 1980c10 View PostI'm just not sure what the differences between the aod and aode are, I would assume the convertors are interchangeable as long as you get one from a 5.0 but .......
