well shit, thats an easy mod for saving around 200bucks on headers. im also sold on these headers.
In my opinion, the FRPP headers don't make plug changes on P heads very easy.
I can't agree with you. I pull my plugs out often when I run nitrous. I have no complaints. The P specific FRPP headers are an improvement over the old FRPP headers that did not fit the P heads. That is why Ford went with a single header. They fit both heads and they are better designed.
If you use a plug socket with a 6 point external end on it, it is even easier because you can use a ratchet wrench.
X2 Plug changes with the frpp p headers is damn easy.
1984 Grand Marquis GS - CFI-SEFI conversion, Explorer 302, GT40 intakes, GT40P heads, 1.7 roller rockers, HO Cam, ASP Underdrive Pulley, 2.5" Dual exhaust, Flowmaster Delta 50 mufflers, 3.55 Trac-Lock, Rear disk's, Moog cargo coils, ES rear poly bushings, PI front and rear sway bars, 3G alt., Mark VIII fan, custom Auto-meter dash 1990 Crown Victoria Country Squire - Explorer 302, HO cam, dual exhaust, 3.55 Trac-Lock, PI rear sway bar (SOLD)
hey zoomie, does the BBK 1515 header come in other finnishes other than the ceramic coated? id like to find plain steel/stainless that i can paint black.
will they work with GT40P heads is the question...
