Have any pics of them? I'm trying to run my scorpions with my EFI, but the Ford Racing ones I have are too tall, (I can't even run the spacer required to clear the intake, because the spacer makes upper intake too high to close the hood).
there are pictures on here, im at work so cant attach them. and im running a carb with a cowl hood so height is not an issue with me
stack some nuts or washers to get 3/8" and stick that between the upper and lower intake with 2 bolts to see if the hood would close.
Milling a spacer from 1" to 3/8" is trivial with the proper machine. It would not be cost effective though. Spacers are not that expensive and if you sell the wrong spacer, you'll recoup enough money for it to not be worth the hassle.
