Originally posted by Crownvicman289
View Post
hairdryers
I was using the 14.7 because it's atmospheric pressure
Thanks a lot. These posts have helped me immensely, and I'd love to hear any other thoughts that anybody has on either turbocharging in general or folks with experience having turbos on a 5.0sigpic
Originally posted by Mercracer View PostDetonation is what kills blocks at 500HP and lower. Detonation is what will kill an Explorer engine at 4lbs of boost if you mess up. Indepth knowledge of the physics is not necessary to make 500HP from a 302. Having the common sense to pull timing and invest in proper fuel and boost management will go a long way.
What would you say is proper fuel and boost management? A high flow system and an AFPR I would think, with the computer tuned properly. I'm more curious about the boost management.sigpic
Originally posted by Mercracer View PostDetonation is what kills blocks at 500HP and lower. Detonation is what will kill an Explorer engine at 4lbs of boost if you mess up. Indepth knowledge of the physics is not necessary to make 500HP from a 302. Having the common sense to pull timing and invest in proper fuel and boost management will go a long way.1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
