Has anyone ever ran a cobra cam in box panther before?
    Sure. 351w are torquier than 302s definitely. But they're worse on gas for the most part. And fuel injection is almost impossible in a box without a 351w lightning lower, or an aftermarket stand alone setup. Which is what I would want had I went the route of a 351w.
    There is a much cheaper solution...stock truck/van lower with a BC Broncos intake adapter...that's what I ran in my 88 T-bird when I was living in Jersey. The lower was ported, the adapter was port matched to it and the HO upper plenum was cut open fully ported and had 3" of internal runner length removed(thus making for more plenum volume). Still have the parts but won't be using them again...I ran into a good paying job finally and am going to be running a hogged out Professional Products EFI intake(chinese edelbrock performer rpm knock-off).
    When I did that swap(from lopo 5.0 to the 351w) I only lost 2mpg city and highway mileage was unchanged even when I went back to a clutch fan. Good times!
    -Don
      i want to see a 347 stroker efi in a panther. that would be the shit as my buddy had one in a monarch and it was stupid fast....
      1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
      1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbines
        Originally posted by 84merc951 View Post
        i want to see a PROPERLY TUNED 347 stroker efi in a panther. that would be the shit as my buddy had one in a monarch and it was stupid fast....
        Fixed that for you...
          If you're gonna sink a bunch of money into a small block Ferd stroker, make it a 351w based stroker. 408 cubes from a stock block and main caps that won't go for a walk
            351 isnt bad on gas with a six speed behind them buddy has one in a stang and its efi, it also runs 10s on spray hehe its cammed out too pretty nasty little car
              Who has the money for a freakin 6 speed?
                The guy/gal who has money for the tuned and matched 351W stroker?
                  I'd do the six speed if I were to go manual. Might as well go all out if you can.
                    I actually know of a guy who did an EFI 351 swap in a Mark VII and gained fuel economy over the 302 HO that was in there. I believe he's running a 4R70w. The 351 is stock displacement but it has a cam and some other stuff, along with a tune. I forget specifics, but its on lincolnsonline somewhere if anyone really wants to dig it up. Economy with a 351 and non-silly expensive transmissions is possible with the right setup.
                      Im not sure about a properly tuned 347 as i have prof of my buddys monarch being solid for 3 years straight. He walks away from everything with a 5 speed and he gets 19 mpgs hauling ass on the freeway with the a/c on and made 349 hp at the dyno. I agree a 351w stroker would be better for power but if i had the money and could stop throwing parts at my 160 hp 5.0s i would do something else but who has the money for any bad ass builds now days. Anyone here ever put high compression head from a 60s 302 on there gms? I know other car guys with other makes do that swap all day long.
                        this guy here does. good freind of mine
                          I ordered me a set of 1.7 roller rockers today. I don't feel like figuring out what valve covers and shit would be needed for non cobra roller rockers. So I got a set off late model resto. Stock valve covers... yay!
                            SF1. Mercury Colony Park with an EFI stroker. Thing was friggin mean.
                              I hope you like valvetrain noise, and be prepared to buy 6.3" pushrods and FRPP shims as well. I went through all that to get mine installed, I think I'll just try running ungodly high levels of lifter preload when I get back home to try and shut it up.
                              1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
                                6.3" pushrods? Why? Didn't the cobra run the same length pushrods?
