Weres my popcorn when I NEED IT
Exhaust Options
Originally posted by Toploader View PostGents after reading this thread I will be staying with the single exhaust on my '86 Tudor MGM, I thought of going to factory duals, but as the car is a street driven daily NYC driver, well why bother??2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
On a stock lopo, best bang for the buck is a muffler delete. It's cheapest, flows the best, and sounds good, won't be too loud with all the rest of the stock stuff. Do it and you won't be disappointed.88 Town Car (wrecked, for sale)
Replace the muffler with a piece of pipe.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
I would look into spintech mufflers. I wanted to put a set on GMGT but, they are out of my budget. Would be cheaper for you, being states side.
Originally posted by 88Vic View PostThere's no answer to that, it's whatever sounds good to you. You might like Flowmaster 40's, I think they sound like junk.
What kind of sound are you after? We can recommend one based on your preferences.
Stay away from Flowmaster, those drone worse than pretty much any other muffler. Chambered mufflers have a deep rumble but drone a lot. Hooker Aerochambers have the deep rumble but don't drone near as much, they're mostly straight through. A short case Magnaflow will have a decent rumble and not drone.
You'll have to add more than just mufflers to make these cars rumble. Small pipe, 4 cats and low engine output don't make for a lot of rumble, need bigger pipe and highflow cats to get some sound volume. I like straight through mufflers like Magnaflow, Borla and Corsa. The Aerochambers are good too, as are Aero Turbines. Spend some time on youtube, use Mustangs to compare different mufflers. Won't be exact but you'll be able to tell the difference from one to the other.
I usually try a muffler delete first, it's cheapest and you can always add mufflers if you don't like it without much money wasted. I did a muffler delete on my 4Runner, then added a 14" case Magnaflow to quiet it down some. I wish I had left it the way it was, sounded good with no muffler and just the cats and 4" tip.Last edited by 88Vic; 12-08-2014, 06:28 PM.88 Town Car (wrecked, for sale)
+1 my magnaflows don't drone, but they're also out the back and not dumped. I'll try to get a new vid of the 88.
Originally posted by piranah View PostSo I am trying to tuck the exhaust on the wagon, its got headers, and the off road h pipe, but it still sits stupidly low. There are the rear cats which I would love to remove. How do I tuck it up?
As for tucking it up, loosen everything up, jack it up without stressing anything or hitting anything, and tighten everything up. That's the best you can do without welding or cutting.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
on my 90 MGM LS hit a really tall speed bump with my saggy springs ripped the muffler off the pipe so we cut off the y pipe ran it about three feet or so den when cheap and got a thrust turbo mufflers (x2) put those on stops right before axle with turndowns not to loud at idle cruises quiet in town stomp on it and itll yell a bit but not to bad not sure what drone sounds like so dont know if they do or not
