oh yeh cool cool.
1000hp fuel system... anyone run dual intank pumps?
Originally posted by merc91 View PostYou guys have some nice strip projects, The last year ive been seeing the attraction of a strip only build and Im definetly going to buy another merc likely in my 30's realistically and do that. At the same time Even with $5 gal gas prices and up over here, I cant ever see myself with a drag only car and a 4 banger for daily driving lol. This will be my street strip weekend warrior. Im definetly going to do a strip car merc though like you guys got goin.
turbo2265b, where abouts in michigan are ya? Im just over the blue water bridge from port huron. And ive wondered, how do those fuel cells vent?
if you look on mine, there are two braided lines coming out. the one on the right runs into the fuel filter and then into the pump. the one on the left just runs through a hole in the trunk above the rear axle. that is just a line with no fitting on the other endhttp://secondhandracing.com/Home.aspx
