Ok its been quite a while but the 347 - t5 swap is making progress!!!
    ahh k, i think i got it now on the brake thing, i already heard that probably a hundred times already, lol, and my answer is, because everybody and their grandmother has a foxbody, i wanted to be different and its actually been a long time goal of mine to make this car a 5 speed since i got my first merc from my dad, he was going to junk it, i found this site and bought a set of used injectors off a member here and installed them myself, car ran fantastic after that, Scott did an awesome full exhaust on that car for me too, ever since then i was hooked! i blame all of you for my addiction, lmao!
      i found the thread for the big brake swap, looks like i have to do some hunting i'm gonna have to find which spring i can go with to give the car a nice drop, i plan on running mustang bullits with the charcoal spokes and silver lip in a 17" size, i don't want to be scraping the ground but i figure it will have a nice look if its dropped about an inch or so
        for your addiction: you're welcome.
          lol, so addicted its making me go broke, i just ordered the (hopefully) last few odds and ends to complete the fuel system, got an electric fan and some gauges since these cars have nothing but dummy lights. should see a lot of progress over the next 2 weeks, i also picked out the color(s) for the car today, bodywork is starting very soon!
          Nick
            I believe what Gadget was saying in regards to the brake lines is that when installing the newer 98-02 master cylinder on an 88 and down vehicle one would remove the proportioning valve from the frame and discard of it. Now, from that statement one would imagine that the 89 and up models are already missing that valve. Sound correct Thain?
            Yes. 89+ has the prop valve screwed into the side of the master cylinder, not down on the frame. I think there is a simple Tee down there for the front lines, but it doesn't have any valve magic in it.
            88- would need the frame mounted combo valve (its a proportioning valve, a metering valve, and a 'shuttle' valve all in one block, along with a tee) removed and you'd use the prop valve that would be screwed into the side of a late model master cylinder. You'd need to install a tee to feed juice to both front brakes, or use the stock late model non-ABS plumbing. That setup has a brake hose on the driver's side with a tee built into it for juice distribution. Functionally this makes absolutely no difference, you just need fluid going to both front wheels and it will have to come from a single hole on the side of the master cylinder.
              got a little more done today, got some more parts in too, i should have the trans hooked to the engine in the next few days then i'll be posting pics of me dropping the engine in, i have a little more work to do on the car itself before i put it in. I want to spray the bay and pre-spray the support, firewall and inner fender the same color that the car is being painted before i put the rad back in and before we paint the car that way we can mask it off and cover the engine
Name:	fuel linefittings.jpg
                turns out the 93 booster does in fact bolt right up to the factory master cylinder, i also got more of the engine done and got the engine bay ready, also fabricated the pedals and mounted them along with the cable, almost ready to rock and roll!!! next step is getting the fuel system ready, i ordered some more fittings, gotta wait till they come in so i can get the lines plumbed and the fuel cell mounted. my phone broke this past friday so once i get the new one in tomorrow i'll get pics loaded up, i do have some on the point and shoot but i wanna get pics of the pedals and clutch cable tomorrow.
                  got some picture goodness!
                  putting the pedals side by side its apparent some work needs to be done to give the merc pedal assembly a clutch
                  yes i made a booboo and drilled the first hole in the wrong spot, we fixed it once the tube was set in properly and welded it all up
                  got the pedal in but now what, the brake pedal is too wide, the brake pedal from the mustang assembly won't work, sooo, i used the mustang brake pedal as a guide and cut the factory pedal down so the rubber cover fits the merc brake pedal
                  more pics to upload yet!
                    Odd. I used the brake pedal from the mustang, no problem. Make sure your clutch pedal tube is straight, looks kinda odd.
                    I see you have mechanical secondaries.
                    Guess this won't be a daily driver, lol. I feel like that carb is a bit to big for the engine as well.
                    Originally posted by SVT98t
                      the engine bay cleaned up, the booster, master cylinder and pedals mounted!
                      got the engine ready to drop in, just having a hard time getting the car and the engine together to get it done without getting raped for towing!
                        the tube is straight, i used a guide once i made the 2nd hole, the carb is actually vacuum secondaries, so i can cruise with it, it may be a little on the big side but i'll have to see how it is once i get it running, a guy at my shop built the same thing just about and used that same carb and his ran fine so i'm hoping this one does too, lol
                          the brake pedal from the mustang had the booster rod attach further up the pedal, i wanted to keep the booster rod in the factory location, if i would have used the mustang pedal the rod would have been angled up once mounted
                            Ya, I had to cut down the factory panther brake pedal as well.
                              Which hole did you end up using to mount the clutch tube?
                                So I gotta ask, whats with the AC eliminator pulley and no smog pump? You can just eliminate that second belt entirely if you want. It doesn't drive anything now.
