Ok its been quite a while but the 347 - t5 swap is making progress!!!
    thread brought back from the dead! the car runs, it spins tires, lol, i will finally be continuing with this project!
    It has been quite a while since i was on the site, a long long time ago i started a project on a 1986 Grand Marquis, 347 stroker with a t-5 swap.... about 6 years ago..... i finally got my finances under complete control and built up some fundage. At the time i had a problem with the cam bearing install. Sent it back to the machine shop and had the bearings replaced a 2nd time, then the engine sat empty and bare for about 2 years.
    In the last 5 months i've re-assembled the short block, and i ordered the cylinder heads yesterday, the project is finally coming to life!!!
    will post updated pics of the progress in a little while
    Nick
      Sweet! I hope that T5 has some beefy parts in it!
      Good luck!
      -Don
        posting some refresher pics, the new ones will be up tonight, these few pics are from when i first took the engine out, lol
        [/URL]
        [/URL]
        [/URL]
        [/URL]
          Good luck!
          -Don
          That's what I was thinking!
          Looks like a solid project.
            Nothing more badass (and an eyecatcher) like a manual Panther!
            -1973 Volkswagen Bus Westy
            -1986 Honda Magna 700cc
            -2011 Subaru Outback
              more recent pics
              old throw out bearing mount
              new one installed
              beginning of engine re-assembly
              another one
              progress
              oops
              got it out!!! turns out i got the wrong oil pan bolts
              correct oil pan bolts and rails installed
              lifters being installed
              lifters installed
              these will hopefully be here by monday
                oooo shiny!
                  I like where this is going!!
                  -Phil
                    Is that aluminum cylinder heads I see on that invoice? What are the engine specs?
                    Loving everything I see.
                      thanks guys its been a long time in the making, the engine specs are:
                      302 bored .30 over and notched for the stroker crank
                      eagle 347 stroker rotating assembly
                      ford racing high volume oil pump
                      hardened oil pump driveshaft
                      ford racing x303 cam .542" lift
                      pro comp aluminum cyl heads
                      210 cc
                      62cc chamber
                      2.02 intake
                      1.60 exhaust
                      stud mounted bearing, roller rockers
                      ford racing hyd roller lifters
                      ford updated lifter retainers from a 95 mustang 5.0
                      ford racing pushrods (not sure if i'm using these yet, i need to see if they will work once the heads are bolted down)
                      estimated 10:1 compression ratio
                      i'm going to go with a dual plane air gap intake
                      750 or 770 cfm carb not sure yet.
                      speed shop says this combo should be good for about 400hp
                      Nick
                        the biggest thing i am really surprised about is that i remember where most of the parts go and where i put them, most of the engine parts sat dormant in big crates for the last 5 years or so, this is my first ever build from the ground up, i'm taking my time and building and torqing to spec, i don't want a bomb when i finally start it.... lol
                        Nick
                          Awesome, glad to see this finally getting picked back up. Did you buy the heads assembled? I've heard horrible things about the assembled pro comp heads using super cheap parts. Everybody says get'em bare and put quality parts in and you're good to go. I've got a bare set awaiting build out but they're the smaller 180's I believe. Can't wait to see this bad boy up and running!
                          Good luck!
                          -Don
                            Good luck!
                            -Don
                            I thought I remembered reading on sbftech those pro comps were garbage, at least the older assembled ones.
                              Yeah, the assembled ones apparently are. Not trying to rain one anybody's parade. Just looked at that invoice again and it looks like a Pro Comp shopping spree! I've had terrible results with their roller rockers...very inconsistent dimensionally.
