e7te id
    e7te id
    Is there a way to identify the e7 heads while the engine is fully assembled & in the engine bay?
    Thanks Guys
    How about e5's?
      Not really. E6 you can ID from the goofy recessed spark plug hole, but otherwise I believe the E5 and E7 are pretty much indistinguishable from anything else or from each other. They're pretty near the same casting anyway as far as I understand it.
        Ok cool, so if it takes the standard HO spark plug it is either the e7 or e5.
        Thanks
          Or one of the ones that came before it. Starting in the mid 70s sometime they went to that same small plug.
            The casting is on the underside of the head on the intake side. with the lower intake manifold removed you can use a mirror.
            other than that the easiest way to tell the difference between E6 and E7 heads is the spark plugs.
