Electric Fan swap relay?
    sorry... 14x1.5 (metric)
    also, I would probably use one of those adapters you put in-line on a radiator hose.
    They make replacement thermostat housings for Panthers that have a threaded port on the top side, its NPT when you buy it but could possibly be drilled out and re-tapped for the BMW switch.
    Originally posted by magnus77 View Post
    I think this guy did what you guys are describing: http://www.gmtruckcentral.com/articles/markviii.html
    Yup, pretty much that setup, just a different fan. The MkVIII fan is a huge power hog, it moves ridicuous amounts of air tho, but may me a bit overkill for the job. Anyone tried running Tauris 2-fan assembly instead? Them are simple 2-wire single-speed motors, so you give each one its own relay and you can end up with three speeds - big fan only (this is actually the low speed one), small fan only (the high speed), and both together (the "OMFG she's about to lift a head and needs cooling right the fawk NOW" speed). Mind you the low speed alone was enough to keep my diesel in check unless I was pulling a steep grade, so IMHO it may be a good choice for a panther as well. I can verify fitment of the Taurus assembly onto a Panther radiator if someone is interested...
    I had one fan controller die in traffic and leave me stranded.
    I had one switch die in traffic and blow my rad.
    I switched back to a mechanical fan and magically all my problems were gone. No more of that electric BS for me.
    See that's why I didn't use a fan controller with my Taurus fans. Low-speed fan was just on a manual switch, high-speed fan was on both manual switch on the dash and a temp switch on the engine. Cruising around mostly empty I could run with both fans off at speeds over 40-45 mph, when she was working harder I'd flip the low fan on, and if I knew there's a steep grade coming up I'd flip the high fan on also well in advance so I have a runnig start at it so to speak. The auto switch was there for when truck was idling for prolonged periods of time unattended, that's about the only use I ever got out of it. But point is, there were no fancy controllers involved, and if a switch died all I had to do was pop the relay off and manually jump the #30 and #87 contacts in the contact with a short piece of 12awg wire with spade connectors crimped on its ends (which I made just for that purpose, and it always lives in the glove box, actually I have more than one of those) - I wanted it as dumb and field-serviceable as possible, and it never let me down.
      I don't like having to manually control my cooling system. We had automatic control in the 1920s. No need to go backwards from there. Also, I'm retarded and its a sure bet I'd forget to turn it on and cause myself problems.
        I admit that I like the electric fan in my '89 Firebird. Doesn't seem to be a powerhog and always keeps the car cool despite its lack of a grille. not very noisy IMO and has never failed. Also, is it just me or does the A/C work better with an electric? In traffic the mech fan sucks for that.t
          It helps more with R134. I've been considering adding a small electric pusher fan for AC use only. I just can't bring myself to rely on an electric for primary cooling again. I've run out of ambition to fiddle with things continually, so fans that I need to worry about a clutch change every 100k miles or so are right up my alley.
            Well I would have installed another temp switch for the low-speed low-temp fan, but I ran out of ports to put them in. Couldn't do the BMW switch either as its settings are way too cold for my needs - that engine runs at 210-215 ideally, meaning them fans would be running full speed all time and working against what I want them to do. And given that the overall pattern was simple enough (no load and flat needs no fans, load or hills needs low fan, leave high fan to the auto switch) I was okay with leaving the low fan on full manual controls. But yeah, I'd have definitely dropped in a 2nd switch if I had somewhere to install it, I like self-controlled gadgets too. Point was, no need for an electronic "controller" of dubious quality, when simple temp switches and relays can do the same thing.
              I run 2 of the hurrican force winds taurus fans each on a seperate relay triggered by my afternarket ecu but plain jane 40a relays work fine but i popped in 80a versions anyways. You could just trigger the relay(s) with a basic grounding $20 temp switch that grounds at whatever temp it's desined to do do... Have your ground wire of the relay run to 1 of those threaded into idealy an upper intake- pre-rad coolant source and you're gold.
                So i bought this ford multi speed fan relay from this site:
                http://www.dccontrol.com/relay_controllers.htm
                Should solve the problem. Came in today, it's a two speed controller with a temp adjustment.
                1985 LTD Crown Vic, factory hard top, 302 soon to be gt40p headed (lightly ported & blended), summit brand stealth (port matched), stock cam, summit annular 600cfm VS, dual exhaust, 3.55 LSD, AOD, electric fan swap, tan interior.
