Originally posted by Grand Marquis GT
View Post
On3 Turbo
Just keep the future mod suggestions within your realm of actual knowledge combined with not goving false credentials and all parties involved win without the need for anyone to be doled out a spanking.
Allot of learning sponges here which is great, we/they really don't need mis-information (eg 10psi is like doubling a 302 into a 604)
Back to the original discussion, i'de defenitly add that buying a used turbo is like buying a well used set of underwear... Non of the history they have is a good thing for you. They are nice and cheap turbos brand new, look after it from new and snag a nice cheep kit with piping and couplers. Their plain steel turbo manifolds/headers are great pieces too. All the little stuff really adds up... I'd not take on the tubo project until a good 2Grand is sitting their.
Hopefully some others who have ran turbo (non-linear relation to rpm like a supercharger) on ford computers will chime in with how well the setup can meter/fuel the air. Corral would likely have lots of good info in that aspect of foxbody stuff.
Good luck buddy, would be killer with a turboFinally have an on the books porting/custom fab business!
Your going to find widely mixed reviews about "Chinese" turbos. Apparently the big thing is proper oiling, some late model cars make very high oil pressure, and from what I've researched some need an oil feed restrictor, others are burning up with the restrictor. Either too much pressure and your blowing oil out of the seals or not enough and the bearings fry.
The magical number(from my searching) seems to be 40-50psi, over that use a restrictor. You can always build your kit, use a cheap turbo and get a little tuning in before stepping up to a better turbo. Borg-Warner has some pretty good, cheap turbos out there $400 and up and I don't hear anybody complaining about them.
Good luck'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Originally posted by sick88tbird View PostC'mon turbo2256b, we've already been though this, please stop posting incorrect information and outright lies as fact. You know not of what you speak and you have claimed to be Bob Natkin, which you're not, everyone here knows you as "David"...and no, that's not the real Bob Natkin's middle name or anything of that sort...oh yeah, the Bob Natkin you claim to be, he NEVER worked for schwitzer...the worst thing you can do is give me false information about yourself then tell me to "look you up". Across every forum you are on, people have the exact same problem with your nonsense...even in boating forums! C'mon guy, you can drop the act and stop the tall tales.
Before this gets deleted or I get banned, isn't what he's doing the real problem? I'm just calling out the nonsense in an effort to better the forums and hopefully have the flow of false information and, at times, outright lies reduced.__________________________________________________
It's over already, thanks Bobcat. Next time I'll be sure to post about it in some secret clandestine section that few people know exists and even fewer have access to.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
