Originally posted by 87GrandMarq
View Post
Header opinions/option
Originally posted by 87GrandMarq View PostI couldnt come anywhere near that unfortuneately, if I really needed a smog pump itd be a different story. I appreciate it though.
Originally posted by Elias View PostNot sure tomorrow ill swap it out then see how much it will be to ship shouldn’t be alot since its not that heavy
Originally posted by 87GrandMarq View PostSounds good man. Do you use tapatalk? I dont know if its just because people dont answer but it seems like I wont get some pm’s through the site but I will get them through tapatalk.
Forgot to post final finish it but im happy how it turned out little rumble when accelerating from stop light but really quite while driving on freeway unless passing a car is need. Almost sound like my marauder which i like. Wish I could post a video don’t know it if possible ill take more pic later
Just went through your thread and saw you're using bbk shorties, bbk mustang h-pipe, and magnaflow mufflers. Is it custom from the mufflers back?1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
Originally posted by sluggish91 View PostJust went through your thread and saw you're using bbk shorties, bbk mustang h-pipe, and magnaflow mufflers. Is it custom from the mufflers back?
Summit has the 54017 on clearance https://www.summitracing.com/parts/wlk-54017/ Good luck on the 54016, seems to be out everywhere.Last edited by knucklehead0202; 12-12-2019, 10:37 AM.
