What am I going to run into dropping this monster into a Box?
385 swap into a Box.
I'm thinking probably the same issues stuffing a 351 in there... finding the specific accessory brackets needed to hook everything up. The engine itself should fit fine with a low profile intake (short runners).
The TKO would die behind the plan I have. Quickly. 4.44x4.50 I cant seem to find any info on oil pans, mounts, ect. Block is a D1VE-A2B. I'm about to say eff it and stuff it into the whale... Probably not a good idea. Or the 03 Exploder, DEFINITELY NOT a good idea...2008 Mercury Grand Marquis GS Bone Stock
The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
Originally posted by RugerP97DC View PostThe TKO would die behind the plan I have. Quickly. 4.44x4.50 I cant seem to find any info on oil pans, mounts, ect. Block is a D1VE-A2B. I'm about to say eff it and stuff it into the whale... Probably not a good idea. Or the 03 Exploder, DEFINITELY NOT a good idea...
Originally posted by Mercracer View PostAre you still looking at doing a swap project?
I want to do a turbo 460. Not sure what route I am going to go with that yet.1983 Grand Marquis 2Dr Sedan "Mercules"
"Barn Find" ... This was posted on FB marketplace for $200. D0VE-A block with the boss front bulkhead! Date code is 9F27 (June 27, 1969) and it has never been bored.
https://www.460ford.com/threads/boss...lained.161937/
I'll be interested to see how the Fox mounts work for you.
The new 7.3 Godzilla has replaced a stroker windsor in my plans and it will have plenty of Fox Swap support to start with.1986 Country Squire
1969 Mercury Cougar
1960 Land Rover Series II 88"
