that it's also time to finally do the front wheel bearings. How hard a job is this? Guess I should do the front brake pads too.
Almost forgot
Really easy, Pop the dust cover off with a pair of channel locks. Then take out the cotter pin followed by the lock. Then take off the nut, slide the rotor towards you a bit then push back and remove the washer and bearing. Then take the rotor off and remove the seal followed by the other bearing....Thats it. Make sure you pack the new bearings with grease.
Nope, they make a tool to pack wheel bearings but you can do it yourself in the palm of you hand...just gets dirty thats all. I always used a ford/lincoln/mercury approved grease when I did mine.
That or maybe Mobil 1 synthetic all purpose grease. Gonna hit all the grease fittings while Im at it, had the pep boys do it and they missed a bunch but what do you expecct fo $10
the bearings fall in and out. You will need to replace the dust seal on the back of the rotor to get to the back bearing. That can be replaced with a screwdriver and a hammer. No special tools needed.Builder/Owner of Badass Panther Wagons
yup yup, what he said about the bearings and the races. If they're shot, you'll need to drive the races out, but all you need for that is a punch and a hammer. To install, you need a socket to drive them in.86 Lincoln Town Car (Galactica).
If you ding any of the bearing race seats or bur them fix that to or they wont seat properly. Check for positve projections in these areas. Some if done before already do. You can see or feel them. They can be peened down with a well dressed punch or a julers file in some casess.Scars are tatoos of the fearless
Good Point.Originally posted by MeLikeyStripperChicksMercenvy, not necessarily - like if he's installing new rotors the races are already in there so he can purchase the bearings only and they'll fit right in. NAPA sells them both ways, just gotta be careful when ordering.
My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
