Posi Differential Info
    All lockers have the same performance result. The disengagement and re-engagement is what changes between the models. In other words when it reaches a point at which it would disengage it changes to open smoother. For the price of a locker you might as well get a torsional diff, unless you have 500hp+ or go rock crawling with your wagon. HAHA, now that would be awesome!
      Good info. See you added it to the FAQ... I'll probably unsticky this thread soon...
        Originally posted by Blaze86Vic
        A spool is simply not drivable on the street. You will be skipping tires through every turn, whether you are going 50mph or 5mph.
        Not to mention that if you get caught in the rain, you better be careful. Im still debating whether or not to go with a full spool when i build a rear end.
        Also they also make Mini-Spools. it is a chunk of metal that replaces the spider and side gears in you regular carrier, does the same hob as a full spool, but are cheaper, however they are not very strong and are only recommended for dirt track and stuff like that. Im not advising anyone to use one, just including it in here to cover it.
          Shewt! dont y'all forget weldin up the spider gears gives ya locked axles too! Dangit! :cowboy:
            I figured so, but for a while we can get some input and maybe add some info.
            I will not support Jerry Rigged jobs hehe.
              First of all, great write up Blaze. I know i want to upgrade to 3.55 gears and my plan was to swap a K code in because it seemed like what everyone on here had/wanted, but now i'm not so sure the trac lock is what i need. My car is a daily driver, about 60% city and 40% highway. I usually dont drive to aggressively but get on the gas someimes. What would be the advantages/disadvantages to a trac lock? It seems like it would be somewhat helpfull if i'm stuck in the snow, but are there any major disadvantages to consider? Thanks in advance...
                No major disadvantage to a K code, because it is a limited slip (and a weak one at that). Go with a K-code.
                  K code it is. Thanks for the advice blaze.
                    Just for the hell of it. here is the Ford trac-lok rebuild kit, this is about the same price as ADTR, so support a sponsor and go through them.
                    Now if you want to go up a step these are the new carbon fiber trac-lok discs.
                      Welding dont work good. Tried it. Ussualy wind up grenading rear ends.I still aint decided to go detroit or not yet when I put gears in.
                      1989 Grand Marquis LS
                        Are they carbon or kevlar? I have some clutches in mine that cost about the same and were factory parts. They were a TSB on explorers for shudder IIRC. The spring can be upgraded to the truck spring for less slip from what I've read. I need to find out for myself. Mine was rebuild last year, and only has about 10K on it and is slipping quite a bit with the amount of power I am making
                          In the most recent 5.0 Mustangs & Super Fords they did a install of these andx they said that they were carbon fiber. CF can make great friction materials, Amerian LeMans Series cars all run carbon fiber rotors.
                            Wonder if it's the same stuff...
                              Metro references them here apparently they are OEM on 03-04 Cobras.
                              http://www.fordracingparts.com/parts...tKeyField=6942
                              http://www.mustangforums.com/m_2930208/tm.htm
                                Do the carbon clutch packs have anything to do with the Cobra IRS diffs requiring that special super-stinky friction-modifying Motorcraft gear lube?
