Having an issue with an '89 Grand Marquis. Under light acceleration, there are no issues. Under moderate to heavy acceleration from a stop, after starting to move, the car will suddenly slip out of 1st for a few seconds before suddenly slamming back into gear. The issue is intermittent (more often not happening). All other shifts work exactly as expected with no sign of funkiness while accelerating or cruising.
The car did have a transmission fluid smell when it was purchased. I took a look and it was hopelessly overfilled, but color was fine. I drained it to the correct level, but the intermittent shift issue never went away.
Any ideas what's going on here? This problem seems weirdly specific, and I can't find any one else having the same issue when I try to Google it.
