A massive one too - I'm getting less than 10mpg around town even though I take my time accelerating and don't race no one, I have to pretty much floor the gas to get the car to move, and then if I back off it starts slowing down real fast, has no inertia at all. Tire pressure set to 45psi (C-load truck tires), engine runs on synthetic Mobil 1 oil and filter, oil and ATF withing correct ranges on dipsticks, brakes don't drag. It's getting ridiculous already, not only am I paying shitload of money for gas, but today when leaving the bonfire at school I had to nail it to get going and security decided I'm showing off and are after my head again! Any ideas what the hell is going on with the damn car?
drag!
Not as bad as when she's in D, but sill worse than anything I've driven, including my truck with them bigass tires. Also I had the chance to drive a 2001 ex-CVPI, she was rolling real nice even when in gear. My tires ain't got no studs no more, and they are smaller than the swampers on the Chevy, and they are actually overinflated compared to the FoMoCo recommendations.
you sure a caliper or a wheel cyl isnt hanging up? parking brake stuck? how bout the wheel bearings? bearings in the rear, universal joints.......check all those things could be the transmision too
Do you still have the air shocks on that car? Is the car lifted as a result? I want you to conduct an experiment: I want you to let all of the air out of the shocks, and then test-drive it again. If it fixes the drag, let me know immediately...and I will tell you what happened.
Originally posted by Pirate View PostDo you still have the air shocks on that car? Is the car lifted as a result? I want you to conduct an experiment: I want you to let all of the air out of the shocks, and then test-drive it again. If it fixes the drag, let me know immediately...and I will tell you what happened.
Originally posted by MeLikeyStripperChicks View PostYes I have air shocks, and yes the car is lifted, but not cause of the shocks - I have HD station wagon coils in the rear, there's brely any air in the air shocks, when I let it out the car lowers less than 1/4", when nothing in trunk it's just coils that carry the car's weight. So I can't really lower it by airing out. Why, what's up with the air shocks and the lift? I've had that setup for almost two years already, never given me hard time before...
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by MeLikeyStripperChicks View Postdunno condition of rears, how do I check?
Originally posted by mrltd View PostAlignment
Originally posted by 1987cp View PostKind of groping in the dark myself here ..... have you checked your tailshaft bushing? Have you tried pushing the car with the driveshaft removed?
Originally posted by Nathan in MN View PostIf the rear axle bearings are going bad, they'll make a rumbling/grumbling noise as you go down the road. Basically what happens is that instead of having the load supported by several of the rollers at once, the load is supported by one at a time, which they're not meant to do. What you're hearing is the load switching from one roller to the next, to the next, and so on. I'm not sure that'd add much rolling resistance, though.
