can i use 98 upper ball joints for a big brake up grade
ball joints
yes, but the geometry might be slightly funny if you're using them on 92-95 upper arms. The ball joint will sit at a slight angle relative to the spindle. Not sure if that will cause them to wear out faster or if that would be any different from 96+ uppers. It will bolt together though.86 Lincoln Town Car (Galactica).
