has anyone tried putting on the seperate rotor and hub assembly from a '92-'94 panther on to a pre '91 panther?
'92 merc rotor/hub on a '88 merc?
2011 Ford Crown Victoria Police Interceptor (Down with O.P.P)Tags: None
If you change the spindle, upper control arm, and lower ball joint it works. Same work as a big brake swap, but no improvement in brake performance.86 Lincoln Town Car (Galactica).
thats what i was getting at, that the spindle has to be changed...right on
