air suspension
    air suspension
    did the 1987 grand marqs have air auspension
    Only lincolns that I'm aware of.
      No, but auto-level rear suspension was optional. Basically it was air shocks connected to a compressor. There is a level sensor and a controller that will run the compressor or open the vent to keep the ride height. If you have it, you'll see a compressor under the hood behind the washer fluid bottle. They still have regular coil springs and you can tie that compressor into aftermarket air shocks pretty easily if you want to keep the system. It is sort of handy if you tow or load lots of stuff in the back or the trunk.
