I like the stock size only because they're so cheap. But I figure you can easily stick a 235 75R15 in there too. Any preferences?
Replacement tires - what size do most go with?
95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
96 Buick Roadmaster Limited Wagon, mostly stock
77 Ford F150, 400M auto, longbed
98 Suburban LS 5.7L Vortec, stock
90 Grand Marquis, stockTags: None
225/70/15 was the police size, it's better than stock
but for the ultimate tire upgrade get 98-02 panther 16" wheels and run 225/60/16's
what are your goals?
price? handling? ultimate grip on acceleration? ride quality? Are you going with lower (numerically higher) rear gears in the future?
In general 215/70/15 or the aformentioned police size seem best. I'm currently running 205/70/15 without any real issue besides a very slightly off speedo, and have run 205/75/15s without issue either.
I LOVE 225/60/16s.sigpic
I liked my 235/75/15's. On the highway mileage improved.1989 Grand Marquis LS
225/70/15s FTW! its an awsome size for 15 inch rims on these cars.
got 245/60/15 fantastic cornering and excellent grip. Will not break loose.90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
Assuming you're not intending to keep your stock 15x6.5s ....
- 255/60/15 is very nice and is stock height, and there's still a decent selection in that size. (BFG, Firestone, Cooper come to mind)
- 235/60/16 is also very nice and is stock height, though selection is more limited than for the shorter-than-stock 225/60/16. Kumho ASXs work OK if you never encounter snow or much standing water.2012 Mazda5 Touring | Finally working on the LTD again!
